hi, on my raspberry pi4 with last version Osmc - kodi 19.1 every video stop playing after 4/5 sec, the same with files on SD card or YouTube video or other addon streaming videos, if I skip a video at some random point playing start and stop always after 4/5 sec., some suggest?
I haven’t costumized something, only a fresh osmc installation.
thank you
reproduce the issue
upload the log set (all configs and logs!) either using the
Log Uploader
method within the My OSMC menu in the GUI or thessh
method invoking commandgrab-logs -A
thank you, I have this result from myosmc
I downloaded log file, I don’t understand how send it, sorry
Apologies. You may need to reboot a couple more times, log generator is unable to upload as it is too big. After reboot(s), please try and reproduce the issue again.
Regards Tom.
hi,
finally I got it :
https://paste.osmc.tv/munahetuna
start to play a video file and it freeze as always after 4/5 seconds, this time added with sad face and blue screen
thank you
I read about release of osmc kodi 19.3, I’ll update as soon as possible and hope this will solve video freezing after few seconds on my pi4
kodi 19.3 installed, nothing fixed and every video files freeze
solved! osmc don’t work correctly if connected to a monitor with an adapter hdmi /dvi.
on smart TV with hdmi cable works
