Video types not supported
Hi there,
after the latest update the addons of Arte, ARD, SpiegelTV and some other addons dont work. The platform says that the data type is not supported or there are no videos at all. So my questions is: Is there an embedded video player in osmc and how can I update/install it or does it depend on the addon which video player is taken?
And second question:
Do you know how to stream webbrowser content and youtube content via yatse app to osmc? I dont get it.
Thank you in advance!
greetings
Skorab
Try contacting the developers of Arte, Ard, SpieglITV etc add-ons. Ask them if it works with Kodi Jarvis (16.x).
Did you upgrade from Kodi Isengard? Not all add-ons are Jarvis compatible yet.
Thanks for your answer but it did not help me.
I have told you where I think you will get the best answer to your question: the maintainers of these add-ons.
I also need more information to be able to answer your question.
To get a better understanding of the problem you are experiencing we need more information, including logs from you. Please see How to submit a useful support request - General - OSMC for advice on how to help us help you.
