you are right but what can i do?
It’s only on this SD video, not on an HD video!
Why is there one core on 100%?
Normally i can record two videos and play one on the same time without problems!
strace first process with 100%:
gettimeofday({1440445318, 44275}, NULL) = 0
read(22, 0x7ef956c0, 4112) = -1 EAGAIN (Resource temporarily unavailable)
clock_gettime(CLOCK_MONOTONIC_RAW, {16530, 958567458}) = 0
read(20, 0x76f4d000, 4096) = -1 EAGAIN (Resource temporarily unavailable)
clock_gettime(CLOCK_MONOTONIC_RAW, {16530, 959309542}) = 0
clock_gettime(CLOCK_MONOTONIC_RAW, {16530, 960154490}) = 0
clock_gettime(CLOCK_MONOTONIC_RAW, {16530, 960573917}) = 0
clock_gettime(CLOCK_MONOTONIC_RAW, {16530, 960825375}) = 0
clock_gettime(CLOCK_MONOTONIC_RAW, {16530, 961255115}) = 0
clock_gettime(CLOCK_MONOTONIC_RAW, {16530, 961506208}) = 0
clock_gettime(CLOCK_MONOTONIC_RAW, {16530, 961741886}) = 0
clock_gettime(CLOCK_MONOTONIC_RAW, {16530, 962102458}) = 0
clock_gettime(CLOCK_MONOTONIC_RAW, {16530, 962446938}) = 0
clock_gettime(CLOCK_MONOTONIC_RAW, {16530, 962692979}) = 0
clock_gettime(CLOCK_MONOTONIC_RAW, {16530, 962930583}) = 0
clock_gettime(CLOCK_REALTIME, {1440445318, 49445047}) = 0
futex(0x154c98c, FUTEX_WAIT_BITSET_PRIVATE|FUTEX_CLOCK_REALTIME, 1977, {1440445318, 149445047}, ffffffff) = -1 ETIMEDOUT (Connection timed out)
clock_gettime(CLOCK_MONOTONIC_RAW, {16531, 63729636}) = 0
futex(0x154c9b8, FUTEX_WAKE_PRIVATE, 1) = 0
clock_gettime(CLOCK_MONOTONIC_RAW, {16531, 64164271}) = 0
clock_gettime(CLOCK_MONOTONIC_RAW, {16531, 64381511}) = 0
clock_gettime(CLOCK_MONOTONIC_RAW, {16531, 64617240}) = 0
clock_gettime(CLOCK_MONOTONIC_RAW, {16531, 64958178}) = 0
clock_gettime(CLOCK_MONOTONIC_RAW, {16531, 65187448}) = 0
clock_gettime(CLOCK_MONOTONIC_RAW, {16531, 65399011}) = 0
clock_gettime(CLOCK_MONOTONIC_RAW, {16531, 65607501}) = 0
clock_gettime(CLOCK_MONOTONIC_RAW, {16531, 65829584}) = 0
gettimeofday({1440445318, 152248}, NULL) = 0
clock_gettime(CLOCK_MONOTONIC_RAW, {16531, 66611041}) = 0
clock_gettime(CLOCK_MONOTONIC_RAW, {16531, 67260729}) = 0
clock_gettime(CLOCK_MONOTONIC_RAW, {16531, 68213958}) = 0
clock_gettime(CLOCK_MONOTONIC_RAW, {16531, 68501770}) = 0
clock_gettime(CLOCK_MONOTONIC_RAW, {16531, 68766093}) = 0
clock_gettime(CLOCK_MONOTONIC_RAW, {16531, 69110468}) = 0
nanosleep({0, 35000000}, NULL) = 0
strace second process with approx 75%:
clock_gettime(CLOCK_MONOTONIC_RAW, {16689, 383290210}) = 0
clock_gettime(CLOCK_MONOTONIC_RAW, {16689, 383665991}) = 0
futex(0x4607884, FUTEX_CMP_REQUEUE_PRIVATE, 1, 2147483647, 0x46078b8, 3704) = 1
futex(0x46078b8, FUTEX_WAIT_PRIVATE, 2, NULL) = -1 EAGAIN (Resource temporarily unavailable)
futex(0x46078b8, FUTEX_WAKE_PRIVATE, 1) = 0
futex(0x46078d8, FUTEX_WAKE_PRIVATE, 1) = 1
clock_gettime(CLOCK_MONOTONIC_RAW, {16689, 384527450}) = 0
clock_gettime(CLOCK_MONOTONIC_RAW, {16689, 392102709}) = 0
first process:
% time seconds usecs/call calls errors syscall
58.57 46.828568 3874 12089 1781 futex
14.68 11.740000 122292 96 select
11.29 9.026202 2167 4165 nanosleep
9.84 7.870000 26769 294 poll
3.00 2.395956 46076 52 recv
2.57 2.058303 1249 1648 ioctl
0.02 0.019794 1 23764 clock_gettime
0.01 0.007104 22 320 286 read
0.01 0.005914 227 26 send
0.00 0.002093 1047 2 sendto
0.00 0.001670 5 343 gettimeofday
0.00 0.000000 0 2 write
0.00 0.000000 0 1 munmap
0.00 0.000000 0 18 mprotect
0.00 0.000000 0 33 _llseek
0.00 0.000000 0 169 sched_yield
0.00 0.000000 0 19 mmap2
0.00 0.000000 0 32 32 stat64
0.00 0.000000 0 14 recvfrom
0.00 0.000000 0 1 sendmsg
0.00 0.000000 0 2 1 recvmsg
100.00 79.955604 43090 2100 total
second process:
root@osmc:~# strace -p 1049 -c
Process 1049 attached
^CProcess 1049 detached
91.10 0.001853 1 2260 81 futex
5.06 0.000103 1 105 ioctl
3.83 0.000078 0 13233 clock_gettime
100.00 0.002034 15598 81 total
If it’s only this video, it would be wise to provide mediainfo on it. There are instructions on how to do so in my necessary info sticky.
Every day it’s a new news recorded video from KIKA-TV “logo! Die Welt und ich.” (logo! Die Welt und ich…ts) for children.
root@osmc:/home/osmc/tvheadend# mediainfo logo!\ Die\ Welt\ und\ ich…ts
General
Complete name : logo! Die Welt und ich…ts
Format : MPEG-TS
File size : 480 MiB
Duration : 13mn 28s
Overall bit rate : 4 978 Kbps
Video
Menu ID : 28008 (0x6D68)
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=12
Format settings, picture structure : Frame
Codec ID : 2
Duration : 13mn 27s
Bit rate mode : Variable
Bit rate : 3 827 Kbps
Maximum bit rate : 15.0 Mbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Active Format Description : Letterbox 16:9 image
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.369
Stream size : 369 MiB (77%)
Audio #1
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Codec ID : 4
Duration : 13mn 28s
Bit rate mode : Constant
Bit rate : 256 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Delay relative to video : -572ms
Stream size : 24.7 MiB (5%)
Language : German
Audio #2
Format : MPEG Audio
Codec ID : 4
Duration : 13mn 28s
Bit rate : 192 Kbps
Stream size : 18.5 MiB (4%)
Audio #3
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : 129
Duration : 13mn 28s
Bit rate : 448 Kbps
Channel positions : Front: L R
Bit depth : 16 bits
Delay relative to video : -455ms
Stream size : 43.2 MiB (9%)
Language : German
Text
Format : DVB Subtitle
Codec ID : 6
Language : German
Menu
Duration : 13mn 28s
List : 310 (0x136) (MPEG Video) / 320 (0x140) (MPEG Audio, German) / 321 (0x141) (MPEG Audio) / 325 (0x145) (AC-3, German) / 331 (0x14B) (DVB Subtitle, German)
Language : / German / / German / German
Service name : KiKA
Service provider : ZDFvision
Service type : digital television
@michaMEG
Where are you playing the file from? local network/sdcard/internet?
I’m playing the “logo!” file here and have low cpu with omxplayer or mmal.
I need to work out how to reproduce the high cpu before I can try to fix it.
From local sdcard
- First the raspi is recording “logo / SD” from 7:50 to 8:05 a clock then “tagesschau / HD” (from an other station) from 8:00 to 8:20
- after recording both the “logo” video is jerking / the “tagesschau” video and other SD/HD (from an other stations) videos are Ok.
- after reboot the “logo” video is Ok!?
Hardware:
- Raspberry PI 2 Model B (without overclocking)
- Sundisk microSDXC Ultra 64GB, Class 10, UHS-I, 48MB/Sec
- original 2A raspi power supply
- D-Link USB 2.0 4-Port Hub
- Sundtek MediaTV Pro III (DVB-C)
- Sundtek MediaTV Pro I (DVB-C)
I also have the same problem with sound lagging for some secounds, I am useing the SPDIF module here:
https://www.raspberrypi.org/forums/viewtopic.php?f=100&t=93522
And I upgrated to the newest OSMC version.
Here is the log so hope anyone can help me with fixing this problem ![]()
http://paste.osmc.io/odefayepat.vhdl
I have tried both with wifi and cable, but still the same.
With the new version it’s the same …
I think there is also an memory leak:
- then “tagesschau / HD” (from an other station) from 8:00 to 8:20
- playing short the jerking “logo”
- playing “tagesschau” (without jerking) / also recording an other SD-Video (not from kika)
- near the end of “tagesschau” (15 minutes) the raspi slow down and the memory is 100% in use
- reboot: everything is normal
I don’t know why but recording with “Stream Profile: matroska” is an workaround for my problem!
Hi there,
I’ve had this or a similar issue. I have TVHeadend running on the same machine as OSMC.
What fixed my problem: in PVR Addon settings of TVHeadend client, I had to point at 127.0.0.1 rather than the network adress of my machine.
Of course, this is not update related as I first thought. However, it might help anyone else around here.
Best wishes
This might be coming a bit late, I recently had a similar issue and after trying just about every option provided here, i realised that the issue only occurred when i was watching SD TV contents, and the CPU usage was around 80% average, while HD TV contents streamed fine with average usage of 20%. This really got me wondering how that was possible, HD should require more power than SD.
Then i realised the codec purchased for video and audio, werent added to config.txt file after reformatting my sdcard, this by my understanding controls the usage of onboard GPU instead of CPU, which was while i was having the delay. After adding it, normalcy was restored to my world lollll.
