Has there been some update?
When I look at my video files, I notice that now under the file name the date of the file is indicated. Also, most importantly, the indicator circle to the left of the file name that shows how much of the file has been viewed no longer works properly.
The viewed indicator, which is a solid white circle when a file has been viewed, disappears when another file is watched or you move out of the folder in which the files are organized and then return.
Can this be fixed?
reproduce the issue
If available, the date has been shown below files or library items for years already…
Regarding the watched indicator: I’ll try and reproduce this on my test setup later today, but any strange behaviour is probably a Kodi regression and not related to OSMC or our skin. The skin only uses information it gets from Kodi to show this indicator.
I did a manual update and the indicator is back to normal and no more file date below the file name. TY for the help.
