Virtual keyboard not working in conlfuence skin after OSMC RC instalation, when i change from OSMC skin to confleunce skin the keboard appears in black, no letters.
Any idea?
Are you set to English language or some other?
That’s definitely odd - I have no such problem, unless it is something which depends on the context in which the virtual keyboard is provoked.
I’ve made that change on Pi1 Pi2 an vero with no ill effect.
Derek
I am using english version… QWERTY
Spanish as principal lenguage in the skin
Did you restore a backup of Gotham ?
No, I have made a fresh install with OSMC RC
