I am trying to play videos stored on usb attached drives to my android phone, I can access files on internal memory but not the external drives. I have tried the file path shown on file manager (which shows my files ok)
What path should I use?
We need a bit more information about what you’re trying to achieve
So this is an eternal drive connected to the Vero?
Did you enable DLNA? Are the Videos in the library?
Sorted, I was trying to use FTP, no luck, I used stp and all now showing
