Main volume works, but amplification in the audio menu is not working after the lat upgrade. This makes the sound to quiet to be usable on some files.
Please test+correct or advise.
Are you using passthrough?
I’m just using the headphone Jack
I don’t believe anything changed in that area. Can you revert to the previous version and double check that it was working on the same file.
