Hey Everyone,
Does anyone know of an Add on or something that I can tweak HDMI audio out???
Thanks,
Kody
Hey Everyone,
Thanks,
Kody
So… after a day… I can assume that there is no equalizer or the such for HDMI volume??? Just the built in offset or amplification???
Kody
Hi. You are right.
Especially if you want to use passthrough audio the audio cannot be changed on the device itself.
There is adsp addon but it is unstable and will break things.
Your best bet would be to do eqing on the tv/receiver where the audio is decoded.
Edit: the digital audio on the hdmi should be only dependent on the source material. Your amplifier needs to do the rest.
Edit2: you could use alsamixer to check the output levels but they should have sane values already.
