VPN client
Hello,
Is there a way to run a VPN client on the Vero 4K ?
Thanks and regards,
Patrick
I would recommend you try this software, it’s a kodi addon to manage VPN.
Haven’t tried it myself since pre september 2020, this is the kodi 19 version(pre release dec-20): Zomboided 6.9.3
Kodi 18.x: Zomboided 6.4.2
Thanks, I will try this.
Regards,
Patrick
This worked for me. Updated to 19.1 went to the link below and downloaded the .zip file onto a USB drive just to make it simple. Went to add on in KODI, Install from zip file, will get a warning that it will not update. Will address that when it is not pre release and use wget. It will install and the wizard will start up where you choose your provider and input credentials.
