VPN Installation
Looking to put a vpn on my Vero 5. I normally usually use zomboid open vpn but have had some issues with it.
Also Brian hornsby add on no longer works. Is there another way, I can get a stand alone version of from my provider, either as android or Debian, but don’t know if they can be used on vero 5.
Any suggestions as to the best way to get it working.
https://web.archive.org/web/20210117174731/https://www.underscorenews.net/2019/07/26/openvpn-setup-for-private-internet-access-for-osmc/
