Thanks stumpy, rebooted and its connected so must be ok, but system info still has my normal ip address.
Also Thanks to all who made suggestions, struggling a bit with my vero at the mo, but getting there.
Do you mean lan ip address or wan ip address ?? or just install speed test gives you all the details direct from the vero. Zomboided wont allow you to connect to the www unless it is working , this is for your privacy, did you get the blue flags on reboot ??
didn’t get blue flags, as I’m using a different skin (nox) but did get a screen saying connecting and then connected. Which speed test do you use?
Arnubox speedtest in the kodi repo
