The vero box is a satellite device for me, that I want to connect via VPN to my home network at startup. The VPN service tells me that I need the Cisco compatible VPN client vpnc.
This is the vpnc config file:
osmc@vero:~$ sudo cat /etc/vpnc/myvpn.conf
IPSec gateway domain.my
IPSec ID myId
IPSec secret mySecret
IKE Authmode psk
Xauth username myUser
Xauth password myPwd
IKE DH Group dh2
IPSec secret-flags 0
Local Port 10000
#NAT Traversal Mode natt
NAT Traversal Mode cisco-udp
osmc@vero:~$
It fails with this error: vpnc: no response from target (see below for full debug trace)
This has to be a problem with the vero box, as it is working with the exact same config (I just did a copy/paste and tried it) on a different device (running Ubuntu 20.04).
Any hint is greatly appreciated.
See here the full debug trace of the failed connection attempt:
https://www.site7even.de/tmp/vero-vpnc.trace
