Wait for network setting in MyOSMC will not stick
Sometimes my OSMC (on a Pi4) doesn’t detect the network on boot, so doesn’t mount a network share.
It’s currently connecting via WiFi.
I have tried to select the “wait for network” setting in MyOSMC => Network => Wireless but the setting will not stick.
The checkbox changes to show the setting has been selected, and then a few seconds later it changes back without intervention. Every time.
Is there a config file I can change manually to make this setting stick?
Thanks!
Can you upload some logs so we can check this?
Here you go: https://paste.osmc.tv/sojukenidi
I rebooted, went to MyOSMC, and tried to select “wait for network” in both the wired and wireless sections. The same issue happens in both.
