I have OSMC running on a Pi 3.
Yesterday I had to do a full reinstall because of a crash.
After reinstalling to the latest version available something strange happened.
After I watch an episode the episode dissapears.
Before it was only marked as watched, which I want it to do.
It is not the filter, thats all cleared.
And I cant find anything in the settings either, rebooting also didnt change anything.
Any ideas?
So, in summary:
- activate the logging
- reboot the OSMC device
- reproduce the issue (here scroll near the end of an episode and let it playback to the end)
- upload the log set either using the
Log Uploader
method within the My OSMC menu in the GUI or the ssh
method invoking command grab-logs -A
- publish the provided URL from the log set upload, here
Thanks for your understanding. We hope that we can help you shortly.
I was about to do the above when I noticed something.
in the tab videos i went over to my disk containing the series.
When I opened the side menu there, the one where you can change the view type and sorting range, I see that there below search it said unwatched. It turns out this is a filter to only show the unwatched series, you can change it to watched and all videos.
When I changed it to all videos and went back to my tv shows tab, I no longer had the beforementioned problem. Now the series I watched have a V in front of them just like before.
It seems strange to me to have this setting in a tab hidden so far away. So if it is supposed to be like that, then I would change it. If not, then I found you guys a bug.
Thanks for the help before.
