WD TV Live IR Remote
Hey guys,
Hope everyone is well!
Does anyone know if there are any remote profiles for the WD TV Live remote to work on the Vero 4k + by any chance?
An image of the remote is below.
On a side note, anyone have any good recommendations of a good IR to use on OSMC
What do you mean by this (keymap, ir reciever that is different than the one built into the Vero, different remote)?
Regardless, I would check out the Flirc USB dongle if you want to use an IR remote. It works much better than going through LIRC and it also supports long-press.
Sorry for the late reply!
I may not have used the term properly or used it without fully understanding the term. Reconstructing, I suppose I was wondering if it was possible to use the WD remote.
In any case, I had a quick search for the Flirc, and it seems like a pretty good product. Thanks for the recommendation. :slight_smile:
