Hello,
I just switched from LibreElec to Vero 4K.
In both systems Im working with Aeon Nox 5 and have installed the addon weatherfanart.multi. In the LibreElec System I choose in the Skin Menue the background "weather". Now I can choose the background in the weather menue. I cant find this option in the OSMC System.
Can anyone help me?
Should be the same if you’re using the same version of Kodi and same skin.
You can backup your settings from LE and move them over
Hi Sam,
thanks for the backup note.
I moved from LE and everything works fine.
