I did stop mediacenter removed “true” but still I can’t access osmc:80 IP:80
<webserver default="true">true</webserver>
<webserverpassword default="true">XXXXXXXXX</webserverpassword>
<webserverport>80</webserverport>
<webserverusername default="true"></webserverusername>
<webskin default="true">webinterface.default</webskin>
What is netstat -tulnp | grep kodi
giving you now?
Nothing, I get back to prompt:
osmc@osmc:~$ sudo netstat -tulnp | grep kodi
osmc@osmc:~$ sudo systemctl stop mediacenter
osmc@osmc:~$ sudo systemctl start mediacenter
First for this command to work the mediacenter needs to be running. So you confirmed that the GUI was on the screen after you started it?
Because I would not have any explanation for not seeing a single entry when Kodi is running.
Sorry for the late reply,
I can’t confirm the gui on screen cause I’m working on a headless server.
Still I can reach anything but osmc.
Since I need that to control music, what do you think if I use a server music player? I checked but I couldn’t find anything similar.
thanks
Osmc is overkill and not at all intuitive if all you want is a music server. MPD on any minimal Linux installation is much better suited for such a task.
i did try mpd but it’s too hard to configure, at least for me.
What I need is music, torrent and minidlna
