Hi there
I installed or activated Bluetooth Audio streaming on my Raspberry Pi 3 as explained here. Well, it kinda works ok if I use an external Bluetooth Dongle, the internal BT is just not working and stops streaming after a random number of seconds. The external BT dongle works fine. However - I experienced the following strange and annoying behauviour:
If Audio Output is set to “HDMI” or “HDMI and Analogue” everything works fine and Audio is connected to my audio receiver (Onkyo). I can play, pause and stop as you would expect. All normal.
If Audio Output is set to “Alsa:OSMC streaming to Bluetooth speaker / headphone” then audio is correctly routed to my headphones. If I pause media or Live TV (Timeshift) via Remote or headphone then after a few seconds the system stops (like pressing the STOP button) getting me back to the main menu! WTH?. I can not get a cold beer from the fridge in the other room without searching the just watched episode again and restart it. No pause function anymore. Am I the only one?
What can I do? Is there any logfile or something I can give to you to fix this mega-annoying bug? Or do you need any more information?
By the way, I am using TVHeadend 4.0.9 from the app store on the same Raspberry. Beside TVHeadend there is nothing else working in the background.
Thanks for reading
Norm
