Hi. Using OSMC skin and using the latest 2018-12.1 update. In the homescreen, everything is aligned properly but when the sidebar pops out, it only shows part of the sidebar. Please see attached photo. That’s the sidebar fully out already.
Make sure the resolution is 1080p.
It’s probably set to an smpte mode from the looks of it
Got it. Thanks
Have you turned overscan off on your TV? If you don’t know how to do that, what make/model is it?
Let me check. Thank you.
@grahamh Changing the aspect ratio on tv fixes the problem. Thank you!
