Posting on behalf on a user
Weird visual going on, I don’t know what to call it. Posting a photo here for you to see. Would logs be useful in this case?
Can you take a photo of the whole screen?
Does the issue occur if the user changes skin?
Will ask for it.
You need to zoom up close to see the problem with font.
Also, user wanted to let you know the purple spots on the screen is due to the TV.
Has the output got set to 1080i instead of 1080p?
Let me ask.
In case it helps, the set up is currently vero 4K+ → AVR → TV
Yeah, so set it to 1080p/60 instead (if you can!) and it’ll probably look better. I’ve seen a couple of other posts from people whose OSMC device got mysteriously switched to 1080i during the upgrade process.
Thanks, @angry.sardine Will try that!
@angry.sardine your advice worked. Thank you!
@sam_nazarko Is this intentional? I think you should default the vero at 1080p instead of 1080i. This would give people the wrong impression (that it’s broken). This was a fresh install from Download - OSMC.
No, it’s being looked into.
Please post some log, because I can’t reproduce this on a fresh install, only an upgrade.
I’ll use the log user sent me the other day
Thanks – we’ll check this out.
