I have a newly installed OSMC installation. When I try to run the following command wget -N https://raw.githubusercontent.com/tvdzwan/hyperion/master/bin/install_hyperion.sh I get a fatal TLS error which can be seen below:
I have no idea why this is happening, CA certificates is installed. This is also happening on one of my other Pi’s which is running raspbian. Any idea what is going on? This is a brand new installaltion of OSMC.
EDIT; It even seems to be failing with --no-check-certificate on wget.
Hi, Thank you for the info I did infact see this post. It suggested you wait 6-12 hours and try again.
I was trying to get this installed last night so 12 hours has passed. Not sure why it is happening. Do you get the error if you try to WGET from github?
Thanks, I needed a second opinion on the matter as to my knowledge everything is set up correctly on my pi and network.
As you also having a bit of trouble it’s got to mean something is wrong with GitHub’s certs.
I have contacted their support team so hopefully they will fix the issue soon. I’ll update this thread once fixed!
Yeah I did think to do that but I noticed inside the install script there are more references to wget from GitHub which would end up failing also.
Probably going to be easier for me to wait until they have updated their certs instead of manually downloading each of the dependencies in the script, hopefully its not too long!
Only think I can think of is what you said earlier. The CDN must be at fault. I can see the IP it’s downloading from for you is 103.245.222.133. When I try to connect it is directing me to 62.252.172.24.
Makes me think maybe the server me and @THEM is connecting to is at fault as he is getting a certificate error also.
Your a star! It must be an error with one of their servers as I have added the IP to hosts and it’s allowing me to download stuff from them again!
Hopefully they fix the original issue… For anyone who is getting the same error messages as me please add 103.245.222.133 raw.githubusercontent.com to your hosts file!
