Dear friends,
quite a lot more than in the past I am getting Kodi on Vero to “freeze” while playing movies.
When this happen the GUI is totally stuck and the only way to resume control of Kodi is to either restart mediacenter or reboot.
The movies are played from a Samba or NFS share (cannot recall right now and am writing from office) from a Raspbmc image running on a Pi2 over a cabled Giga network.
I did not try to play the offending movies from local storage (that would be my next attempt if sensible).
The same movies played from the same share via Kodi or VLC from my iMac appear to slightly stutter more or less in the same points but usually resume after a second or so and keep playing.
Is it always on the same movies? if so we’ll probably want to have mediainfo on those particular movies. Might be good to have some logs taken at the same time of the crash.
Thanks. Here is the Mediainfo on one of those movies where things get stuck (in this case well into the movie, almost 1 hour IIRC)
General
Unique ID : 298503760292305023439028547202907470759 (0xE091BBA8E5A3023872251BAC1E7D7BA7)
Complete name : /Volumes/WD1TB/movies/Monsters Inc (2001) 1080p ITA/Monsters Inc (2001).mkv
Format : Matroska
Format version : Version 2
File size : 7.48 GiB
Duration : 1h 32mn
Overall bit rate : 11.6 Mbps
Movie name : “Monsters and Co.”
Encoded date : UTC 2009-12-03 22:19:20
Writing application : mkvmerge v2.9.8 (‘C’est le bon’) built on Aug 13 2009 15:02:06
Writing library : libebml v0.7.8 + libmatroska v0.8.1
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : A_AC3
Duration : 1h 32mn
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 422 MiB (6%)
Language : Italian
Default : Yes
Forced : No
Audio #2
Format : DTS
Format/Info : Digital Theater Systems
Format profile : ES
Mode : 16
Codec ID : A_DTS
Duration : 1h 32mn
Bit rate : 1 509 Kbps
Bit depth : 24 bits
Stream size : 996 MiB (13%)
Title : Main Audio
Language : English
Default : No
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : Italian
Default : No
Forced : No
Text #2
Format : ASS
Codec ID : S_TEXT/ASS
Codec ID/Info : Advanced Sub Station Alpha
Compression mode : Lossless
Language : English
Default : No
Forced : No
Text #3
Format : ASS
Language : French
Default : No
Forced : No
Text #4
Format : ASS
Language : Spanish
Default : No
Forced : No
Text #5
Format : ASS
Language : Swedish
Default : No
Forced : No
Thanks a lot Doctor Nazarko (and kudos for your graduation)
I will try to understand if using handbrake I’ll be able to recode the offending streams within the specs.
I am not sure I know what to use on my Mac to lift off a segment of the video without changing it while saving. Will try to understand and if I succeed I’ll get back in touch.
But now that I’m looking through my old Disney movies I see this freezing occurr a lot. Here is Hercules. It freezes despite my uneducated understanding of the mediainfo would say it lies within the specs you mentioned. Other ideas ? Might this be CIFS related or audio related ?
TIA
General
Unique ID : 220692519146925626092631777626652081083 (0xA607D546E040BA608289D4DCCDD2FBBB)
Complete name : /Volumes/WD1TB/oldmovies/Hercules (1997) BDrip 1080p ENG-ITA x264 bluray.mkv
Format : Matroska
File size : 4.38 GiB
Duration : 1h 33mn
Overall bit rate : 6 727 Kbps
Encoded date : UTC 2014-09-29 21:52:00
Writing application : mkvmerge v7.2.0 (‘On Every Street’) 64bit built on Sep 13 2014 15:52:10
Writing library : libebml v1.3.0 + libmatroska v1.4.1
_STATISTICS_WRITING_APP : mkvmerge v7.2.0 (‘On Every Street’) 64bit built on Sep 13 2014 15:52:10
_STATISTICS_WRITING_DATE_UTC : 2014-09-29 21:52:00
_STATISTICS_TAGS : BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
DURATION : 01:26:24.888000000
NUMBER_OF_FRAMES : 930
NUMBER_OF_BYTES : 39472
Audio #1
Format : AC-3
Codec ID : A_AC3
Duration : 1h 33mn
Bit rate : 640 Kbps
Bit depth : 16 bits
Stream size : 427 MiB (10%)
Title : English Ac3 5.1 chnls 640 kbps
Language : English
Default : Yes
Forced : No
Audio #2
Format : AC-3
Codec ID : A_AC3
Duration : 1h 33mn
Bit rate : 640 Kbps
Bit depth : 16 bits
Title : Italian Ac3 5.1 chnls 640 kbps
Language : Italian
Default : No
Forced : No
Text #1
Format : UTF-8
Title : english
Language : English
Default : No
Forced : No
Text #2
Format : UTF-8
Title : italian
Language : Italian
Default : No
Forced : No
Menu
00:00:00.000 : en:Program Start
00:00:32.824 : en:The Gospel Truth
00:02:28.690 : en:Festivities on Mt. Olympus
00:05:16.566 : en:Hades
00:07:55.392 : en:The Fates Reveal the Future to Hades
00:10:59.617 : en:Hercules Is Kidnapped
00:14:23.196 : en:Jerk-Ules
00:18:28.649 : en:Go the Distance
00:20:12.628 : en:Hercules Sets Out for the Temple of Zeus
00:21:01.469 : en:The Search for Philoctetes
00:25:29.987 : en:Call Me Phil
00:28:21.325 : en:One Last Hope
00:32:08.927 : en:A Damsel in Distress
00:35:20.744 : en:Megara
00:39:12.308 : en:The Big Olive - Thebes
00:44:26.247 : en:The Battle with the Hydra
00:48:29.156 : en:Zero to Hero
00:51:32.548 : en:Hades’ Plan on the Verge of Disaster
00:53:47.391 : en:Progress Report to Zeus
00:55:20.651 : en:At the Villa
00:57:49.633 : en:The End of a Great Day
01:01:18.341 : en:I Won’t Say (I’m in Love)
01:03:47.615 : en:Herc’s Weakness
01:07:44.978 : en:Hades’ Dirty Deal
01:10:27.890 : en:Hades Releases the Titans
01:15:17.513 : en:Inspiration From Phil
01:17:08.457 : en:Hercules Heads for Mt. Olympus
01:19:13.332 : en:The Fates Cut the Thread
01:20:55.100 : en:Hercules Makes a Deal with Hades
01:23:44.478 : en:Reunion on Mt. Olympus
01:26:01.239 : en:A Star Is Born
01:27:03.176 : en:End Credits
Yes – the specs look OK there. For MKV files you can download a file called ‘mkvtoolnix’ which will allow you to split your video into smaller files. If you can, upload the smallest / shortest file you can create that still reproduces this problem and I will take a look.
It would also be good to see kodi.log (in debugging mode) when the Hercules film starts to have problems
