I have been using XBMC for 4 or 5 years now starting with original Xbox, then moving to Apple TV 1 and 2 and also Amazon Fire TV. I’d like to try setting up a raspberry pi 2 (or similar device) to run OSMC. What I’m looking for is advice on what to start. I’m interested in saving money and reliability.
- Which hardware should I get?
- Should I assemble it myself or buy it already assembled? (I can put things together but am not an electronics geek (just a PC geek)
- If I assemble, is there bill of materials somewhere I can use to get what I need?
- Where are good sources of the hardware (ebay, Craigslist, Amazon, etc)?
If there’s info from another source that you can reference that would be helpful, I would appreciate that as well. Thanks for your time.
Well, these are really basic questions.
1.) Basicly you need a Raspberry Pi (or similar device). I faced that questions a few month ago and decided to get a raspberry pi 2 simply because the pi is (afaik) the device which has the biggest community and the best support.
A few beginners guide: https://www.raspberrypi.org/help/quick-start-guide/ or http://lifehacker.com/5976912/a-beginners-guide-to-diying-with-the-raspberry-pi?utm_medium=referral&utm_source=pulsenews or http://kodi.wiki/view/First_time_user
2.) A Raspberry Pi is already “assembled”, the only thing you need to do is plug in all the cables and there you go (well, except you bought a case).
3.) See links above or simply google for “raspberry pi beginners guide”.
4.) Well, just look around and compare offers. That depends a bit on your locations. For example I would have paid nearly the same amount for delivery charges as for the hardware it self on some shops.
