Hi there is there any tweaks i can use the sd card for or is it only for media and so on?
Tried to save my logs on the sd card but no files will not show up.
That’s a good question. I am (or will be) storing a lot of fanart etc on Vero internal memory so was thinking that it would better to do that on SD card.
Not entirely sure how to do that.
Question to Vero dev’s, what can you do with the SD card and how please? Apologies if i missed it in the wiki or forums.
Hu? You mean remove the slot? It has a use other than what the OP asked about. It’s also used to recover from a corrupt installation. But there is no reason why it can’t be used as expansion storage also…
With the Vero 4K, unless I’m mistaken, if you have a major corruption of the internal storage, you need to use a SD card + the ‘toothpick method’ to repair. Also you can use the SD card slot to test a custom kernel without installing it, so it has other uses. Plus, why not use it for extra storage? Looks cleaner than a USB stick
Well, then I’d like to see the ability to do this via USB (if you really can’t already) and make the SD card slot a USB port. And why? Because…
e.g. how much is a 512GB SD card of good quality? And how much is a USB-based SSD?
Let’s be honest, having a USB stick or SSD attached isn’t messy. You’ve already got a power cable and HDMI cable and ethernet cable and who knows what else already connected.
At the end of the day, all things being equal, a USB port is more useful than an SD card slot, if a choice exists for either.
