Hi All,
Apologies for seemingly basic question
Last night I finally got round to finally updating my Vero 1 from the September software to the latest version. The update failed (no signal on tv for approx 20 mins) so I reluctantly pulled the plug.
On reboot mediacenter/kodi doesn’t launch and throws some errors. I can ssh.
I’ve tried to re-install the update using a combination of with no luck
sudo apt-get dist-upgrade
sudo apt-get install --reinstall
Running
sudo systemctl status mediacenter -l
shows the following errors:
mediacenter.service - media center application
Loaded: loaded (/lib/systemd/system/mediacenter.service; enabled)
Active: active (running) since Sun 2017-01-08 17:05:33 GMT; 48min ago
Main PID: 492 (mediacenter)
CGroup: /system.slice/mediacenter.service
└─492 /bin/bash /usr/bin/mediacenter
Jan 08 17:54:09 osmc sudo[7881]: osmc : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/mv /tmp/timezone /etc/timezone
Jan 08 17:54:09 osmc sudo[7881]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jan 08 17:54:09 osmc sudo[7881]: pam_unix(sudo:session): session closed for user root
Jan 08 17:54:09 osmc sudo[7884]: osmc : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/cp /usr/share/zoneinfo/Europe/London /etc/localtime.dpkg-new
Jan 08 17:54:09 osmc sudo[7884]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jan 08 17:54:09 osmc sudo[7884]: pam_unix(sudo:session): session closed for user root
Jan 08 17:54:09 osmc sudo[7887]: osmc : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/mv /etc/localtime.dpkg-new /etc/localtime
Jan 08 17:54:09 osmc sudo[7887]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jan 08 17:54:10 osmc mediacenter[492]: /usr/lib/kodi/kodi.bin: symbol lookup error: /usr/lib/kodi/kodi.bin: undefined symbol: fbGetDisplayByIndex
Jan 08 17:54:10 osmc mediacenter[492]: Kodi exited with return code 127 after 0 hours, 0 minutes and 2 seconds
For those interested my logs are here http://paste.osmc.io/onefedipoj
Unsure if it’s relevant but this doesn’t look good:
Jan 08 17:06:01 osmc mediacenter[492]: /usr/lib/kodi/kodi.bin: symbol lookup error: /usr/lib/kodi/kodi.bin: undefined symbol: fbGetDisplayByIndex
Jan 08 17:06:01 osmc sudo[535]: pam_unix(sudo:session): session closed for user osmc
Jan 08 17:06:01 osmc mediacenter[492]: Kodi exited with return code 127 after 0 hours, 0 minutes and 28 seconds
Reluctantly I suspect it’ll need a reinstall - but I haven’t done this before (updates have always worked perfectly OOTB). Does it completely wipe the system files and reinstall? Would, for example, the OpenVPN install I struggled with for days be wiped etc?
I do have backups of my addons and user data folder so I should be ok there - just curious as to what happens when installing from USB?
Any help gratefully appreciated.
