What is the correct way to setup folder- and filenames (all *.MKV) for series so OSMC can scan for content automatically?
Currently I have following setup:
Folders: Name of serie + S** f.e. Lost S1 or Lost S01
Files: Number of episode + Title of episode f.e. 01 Pilot.mkv
Sometimes I only have the number of the episode as filename f.e. 01.mkv
If my setup isn’t the way to approach this, is there any way to automatically update folders and files, so they are compatible (f.e. with some batch file).
thanks men, looks good that app… and i should use it on windows machine to rename it on my NAS? or install it as a package on NAS and run it from there in terminal?
ok, i used the program for the renaming… now the issue is, that the library takes just first series (series 1), the another one series 2,3,… are not in my library… how to solve this? all episodes are in separate folder, it looks like:
series/series1folder/episodes01e01folder/episodes01e01.avi
