Hello,
I like the layout of this forum, the way to made a new topic and to edit.
Can I have the name of this “engine” (CMS, extensions, others …) ?
Thank you.
Regard.
Hello,
Thank you.
Regard.
The basis is http://www.discourse.org/
But Mark did quite a few customizations.
Ok, thank you very much
Could you please also tell a few more things?
Thank you in advance.
@marktheis will be the staff member in the best position to answer these questions for you
No plugin for that. There’s a setting in discourse for it.
Sam and I made the wiki functionality. Using the json API to get all the content and then render it on osmc.tv. someone from discourse found our wiki system interesting, so maybe they’re working on something similar.
