I try to minimise the number of remotes hiding around the place and so tend to use a One For All device, but I’m struggling to find out what the Vero 4K is posing as. What control set/device should my One For All be set to use to control the Vero?
Yes, no need for FLirc on the Vero4k. You can use eg Logitech Harmony directly with the Vero4k. You can also use any other remote you just would need to train the keys respectively in to profile is available for that specific remote.
You would probably know this if it was an options for you, but if you have a harmony remote with a hub you can use bluetooth. There is a “Microsoft Kodi” profile that works well. A more responsive and reliable option than IR…
