Hi community,
What router model are you using with the Vero4K and what are the largest overall bitrate file you can playback smoothly on it?
Templete:
Router
Brand:
Model:
Movie
Title:
Size:
Duration:
Overall bitrate:
Mounting
Mount-point[fstab/kodi]
Proto[smb/nfs]
via [internal/external wifi adapter]
Living accommodations
[House/Apartment/Terraced house etc…]
Personally, I’m unable to playback high bitrate movies such as 4K content like John Wick or just La La Land… so I’m trying to figure out if others are having success with high bitrate films over wifi and in what environment. I sincerely appreciate the replies.
My own:
Router
Brand: Asus
Model: RT-AC68U
Movie
Title: Contraband (2012) (1080p)
Overall bitrate: 35.8 Mbit/s
Mounting
Mount-point: fstab
Proto: SMB
via internal antenna
Apartment
Router
Brand: Asus
Model: RT-AC87U
Movie
Title: John Wick 2 UHD remux
Total Bitrate: 90.28 Mbps
Mounting
Mount-point: fstab
Proto: NFS
via wired LAN and gigabit USB adapter
Flat
I’ve yet to come across a UHD remux that I can’t play smoothly, for me the key is wired LAN and a gigabit usb adapter. Oh and nfs rather than smb seems to perform a bit better.
I can’t comment on wireless although in theory it should be fine.
Router: Unifi AP AC LR (technically an access point)
Brand: Ubiquiti
Model: AR LR
Movie: Pacific Rim UHD HDR remux
Duration: 2 hrs
Overall bitrate: not sure
Mounting: kodi nfs wifi
Living accommodations: house
Which adapter are you using? I’m thinking about just RJ45-wiring it up for now and dealing with the wifi issue on a continuing basis.
Brand: Self-made
Model: Celeron® CPU J1900 @ 1.99GHz + 2GB Ram + 32GB SSD / 4x1Gbps Intel Ethernet running Ubuntu LTS 16.04.4 LTS with Shorewall 15.x
Movie
Title: John Wick UHD remux
Overall bitrate: 90.28Mbps
Mounting
Mount-point: Kodi
Proto: NFS
via: Ethernet
Living accommodations: House
Note: Cat6 Cabling in the entier house.
