Rapier is my must-have skin.
This should be adressed in the next update⦠The option to adjust the dimming of non-focused cover art has already been present in our skin for a while now (under System/Interface/Skin/Configure skinā¦/Advanced/Dim factor of unfocused art). Iāll probably add another option to that setting before the next update: 0% dimming. This should be what youāre referring to, @bluefuzz. Correct? ![]()
To make out which cover is selected, when using a low-percentage dim factor, the selected titleās cover art is now bigger in size. This new feature takes effect in widgets as well as other cover art views: wall view for movies, TV shows and music as well as add-ons and games under v18 and wide list for movies and TV shows.
An example:
The feature will be available in the next v17 update as well as in the next v18 nightly.
Excellent! Thanks. This should make the default skin a lot more pleasant to use.
