Picture covering only about one sixth of the screen when it should be filling the whole TV. Any ideas why?
Try and reboot, leaving TV and your image processor on.
I’ve already tried rebooting several times.
It doesn’t seem to affect every video, but the ones that are affected play correctly on other devices.
MediaInfo for an affected video file will follow shortly…
MediaInfo:
General
Unique ID : 207088661383220100428660518161063014617 (0x9BCBD34E138E87B4A6D325F81B8AF0D9)
Complete name : E:\Video\Film Emergency Storage\Howls.Moving.Castle.mkv
Format : Matroska
Format version : Version 2
File size : 26.4 GiB
Duration : 1 h 59 min
Overall bit rate : 31.7 Mb/s
Encoded date : UTC 2011-11-18 07:35:49
Writing application : mkvmerge v5.0.1 ('Es ist Sommer') built on Oct 9 2011 11:55:43
Writing library : libebml v1.2.2 + libmatroska v1.3.0
Video
Format : AVC
Format profile : High@L4.1
Format settings : CABAC / 2 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 2 frames
Muxing mode : Container profile=@0.0
Codec ID : V_MPEG4/ISO/AVC
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Default : No
Forced : No
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 224 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Compression mode : Lossy
Stream size : 191 MiB (1%)
Title : Русский AC3, 2ch 224 kbps (полное дублирование)
Language : Russian
Service kind : Complete Main
Default : Yes
Forced : No
Audio #2
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Bit rate : 1 510 kb/s
Channel(s) : 6 channels
Channel layout : C L R Ls Rs LFE
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 24 bits
Stream size : 1.26 GiB (5%)
Title : Русский DTS, 6ch 1510 kbps (многоголосый, CP Digital)
Language : Russian
Default : No
Forced : No
Audio #3
Format : AC-3
Codec ID : A_AC3
Bit rate : 448 kb/s
Stream size : 382 MiB (1%)
Title : Русский AC3, 6ch 448 kbps (одноголосый, А. Гаврилов)
Language : Russian
Default : No
Forced : No
Audio #4
Format : AC-3
Codec ID : A_AC3
Bit rate : 448 kb/s
Title : Русский AC3, 6ch 448 kbps (одноголосый, Е. Лурье)
Language : Russian
Default : No
Forced : No
Audio #5
Format : DTS
Codec ID : A_DTS
Bit rate : 768 kb/s
Bit depth : 24 bits
Stream size : 655 MiB (2%)
Title : Английский DTS, 6ch 768 kbps (полное дублирование)
Language : English
Default : No
Forced : No
Audio #6
Format : DTS ES XLL
Commercial name : DTS-HD Master Audio
Codec ID : A_DTS
Bit rate mode : Variable
Channel(s)_Original : 7 channels
ChannelLayout_Original : C L R Ls Rs LFE Cs
Bit depth : 24 bits
Compression mode : Lossless
Title : Японский DTS-HD MA-ES, 6ch 3986 kbps
Language : Japanese
Default : No
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Title : по дубляжу ОРТ
Language : Russian
Default : No
Forced : No
Text #2
Format : UTF-8
Title : CP Digital
Language : Russian
Default : No
Forced : No
Text #3
Format : UTF-8
Title : ISA (Сергей Ильюшенко)
Language : Russian
Default : No
Forced : No
Text #4
Format : UTF-8
Title : Анна Панина
Language : Russian
Default : No
Forced : No
Text #5
Format : UTF-8
Title : OutSun
Language : Russian
Default : No
Forced : No
Text #6
Format : UTF-8
Title : obaka-san
Language : Russian
Default : No
Forced : No
Text #7
Format : UTF-8
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : en:00:00:00.000
00:01:04.273 : en:00:01:04.273
00:04:58.632 : en:00:04:58.632
00:12:22.825 : en:00:12:22.825
00:18:23.269 : en:00:18:23.269
00:23:16.770 : en:00:23:16.770
00:28:51.939 : en:00:28:51.939
00:33:13.783 : en:00:33:13.783
00:40:10.241 : en:00:40:10.241
00:45:30.394 : en:00:45:30.394
00:49:15.870 : en:00:49:15.870
00:55:26.365 : en:00:55:26.365
00:58:32.509 : en:00:58:32.509
01:04:51.221 : en:01:04:51.221
01:10:53.708 : en:01:10:53.708
01:15:24.353 : en:01:15:24.353
01:20:25.487 : en:01:20:25.487
01:25:19.489 : en:01:25:19.489
01:32:30.879 : en:01:32:30.879
01:38:35.576 : en:01:38:35.576
01:44:22.423 : en:01:44:22.423
01:48:20.786 : en:01:48:20.786
01:52:19.483 : en:01:52:19.483
01:54:39.039 : en:01:54:39.039
Are you using the 3D test build?
It doesn’t look like the 3D test build. The logs show a weird SetVideoRect output, so the “axis” seems to be wrong.
@angry.sardine, is this the only video showing this problem?
I was when I first noticed the problem, but the first thing I tried was reverting back to the standard version, and I’m still seeing the issue.
Not all videos are, but that isn’t the only one that is.
Could you move your guisettings.xml away (stop Kodi first) and see if a fresh one exhibits the same problem?
I could ionly imagine that issue occurring if the Vero was turned on before a 4K TV was then turned on.
I’m not familiar enough with Kodi to know where to find the file. ![]()
Well, I’ve tried rebooting several times. Also, why would that affect some videos but not others?
Here’s MediaInfo for another file that exhibits the same problem:
General
Unique ID : 48900569668494627854517422813926996290 (0x24C9E83A78E164487CB91989C6453942)
Complete name : E:\Video\Film Emergency Storage\Kung Fu Hustle.mkv
Format : Matroska
File size : 14.5 GiB
Duration : 1 h 39 min
Overall bit rate : 20.9 Mb/s
Encoded date : UTC 2019-11-30 10:26:17
Writing application : MakeMKV v1.14.5 win(x64-release)
Writing library : libmakemkv v1.14.5 (1.3.5/1.4.7) win(x64-release)
Video
ID in the original source medium : 4113 (0x1011)
Format : MPEG Video
Format profile : Main@High
Format settings : CustomMatrix / BVOP
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=15
Codec ID : V_MPEG2
Codec ID/Info : MPEG 1 or 2 Video
Bit rate : 16.2 Mb/s
Maximum bit rate : 30.0 Mb/s
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.325
Time code of first frame : 00:59:58:00
Time code source : Group of pictures header
GOP, Open/Closed : Open
GOP, Open/Closed of first frame : Closed
Stream size : 11.2 GiB (77%)
Language : English
Default : No
Forced : No
Original source medium : Blu-ray
Audio
ID in the original source medium : 4353 (0x1101)
Format : PCM
Format settings : Little / Signed
Codec ID : A_MS/ACM / 00000001-0000-0010-8000-00AA00389B71
Bit rate : 4 608 kb/s / 4 608 kb/s
Frame rate : 30.000 FPS (1600 SPF)
Bit depth : 16 bits
Stream size : 3.20 GiB (22%)
Title : Surround 5.1
Language : Chinese
Default : Yes
Forced : No
Text #1
ID in the original source medium : 4608 (0x1200)
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Duration : 1 h 33 min
Bit rate : 25.6 kb/s
Count of elements : 1216
Stream size : 17.1 MiB (0%)
Language : English
Default : No
Forced : No
Text #2
Format : PGS
Duration : 1 h 19 min
Bit rate : 701 b/s
Count of elements : 28
Stream size : 406 KiB (0%)
Language : English
Default : Yes
Forced : No
Text #3
ID in the original source medium : 4609 (0x1201)
Format : PGS
Duration : 1 h 34 min
Bit rate : 19.8 kb/s
Count of elements : 1538
Stream size : 13.4 MiB (0%)
Language : English
Default : No
Forced : No
Text #4
ID in the original source medium : 4624 (0x1210)
Format : PGS
Duration : 1 h 35 min
Bit rate : 73.4 kb/s
Count of elements : 2852
Stream size : 50.1 MiB (0%)
Language : English
Default : No
Forced : No
Text #5
ID in the original source medium : 4627 (0x1213)
Format : PGS
Duration : 1 s 22 ms
Bit rate : 11.5 kb/s
Stream size : 1.43 KiB (0%)
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 01
00:06:57.667 : en:Chapter 02
00:12:24.118 : en:Chapter 03
00:19:44.808 : en:Chapter 04
00:24:47.986 : en:Chapter 05
00:31:14.247 : en:Chapter 06
00:35:36.843 : en:Chapter 07
00:43:38.574 : en:Chapter 08
00:49:18.163 : en:Chapter 09
00:54:14.584 : en:Chapter 10
01:01:04.869 : en:Chapter 11
01:08:33.776 : en:Chapter 12
01:13:25.317 : en:Chapter 13
01:19:55.457 : en:Chapter 14
01:25:46.558 : en:Chapter 15
01:31:53.925 : en:Chapter 16
Here’s MediaInfo for a 1080p file in the same folder that does NOT produce the problem:
General
Unique ID : 214104090773230547100409253791448546119 (0xA112F2ADBE05E279A0A28F516F35BB47)
Complete name : E:\Video\Film Emergency Storage\Hero (2002).mkv
Format : Matroska
Format version : Version 4
File size : 31.5 GiB
Duration : 1 h 49 min
Overall bit rate : 41.2 Mb/s
Movie name : Hero.2002.DC.CHINESE.1080p.BluRay.REMUX.AVC.DTS-HD.MA.6.1-FGT
Encoded date : UTC 2019-10-26 10:01:39
Writing application : mkvmerge v38.0.0 ('The Silent Type') 64-bit
Writing library : libebml v1.3.9 + libmatroska v1.5.2
Cover : Yes
Attachments : cover_land.jpg / small_cover.jpg / small_cover_land.jpg / cover.jpg
Video
Format : AVC
Format settings : CABAC / 4 Ref Frames
Format settings, Reference frames : 4 frames
Format settings, GOP : M=3, N=24
Bit rate : 35.0 Mb/s
Maximum bit rate : 37.0 Mb/s
Frame rate : 24.000 FPS
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.703
Stream size : 26.7 GiB (85%)
Title : Hero.2002.DC.CHINESE.1080p.BluRay.REMUX.AVC.DTS-HD.MA.6.1-FGT
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio #1
Format : DTS ES XXCH XLL
Codec ID : A_DTS
Bit rate : 4 667 kb/s
Channel(s) : 7 channels
Channel layout : C L R Ls Rs LFE Cb
Bit depth : 24 bits
Stream size : 3.57 GiB (11%)
Language : Chinese
Default : Yes
Forced : No
Audio #2
Commercial name : DTS-ES Discrete
Codec ID : A_DTS
Bit rate : 1 509 kb/s
ChannelLayout_Original : C L R Ls Rs Cs LFE
Bit depth : 24 bits
Stream size : 1.15 GiB (4%)
Language : Chinese
Default : No
Forced : No
Text #1
Format : PGS
Muxing mode : zlib
Duration : 1 h 40 min
Bit rate : 19.3 kb/s
Count of elements : 1324
Stream size : 13.9 MiB (0%)
Title : English-PGS
Language : English
Default : Yes
Forced : No
Text #2
Format : PGS
Muxing mode : zlib
Duration : 1 h 43 min
Bit rate : 13.8 kb/s
Count of elements : 1046
Stream size : 10.2 MiB (0%)
Title : Korean-PGS
Language : Korean
Default : No
Forced : No
Menu
00:07:33.666 : en:Chapter 02
00:15:56.708 : en:Chapter 03
00:28:55.666 : en:Chapter 04
00:37:46.500 : en:Chapter 05
00:46:45.958 : en:Chapter 06
00:54:33.916 : en:Chapter 07
01:04:24.708 : en:Chapter 08
01:12:19.375 : en:Chapter 09
01:21:34.583 : en:Chapter 10
01:29:06.375 : en:Chapter 11
01:39:19.458 : en:Chapter 12
I’ve no Vero here at the moment … can you have a look at your settings somewhere (maybe player settings) there’s one setting for the GUI stereo mode. From the top of my head I don’t know how it’s exactly named. What does it say?
Under “Player” settings, “Playback mode of stereoscopic videos” is set to “Preferred mode”. Under “System”, “Preferred mode” is set to “Same as movie”.
But these are 2D files I’m playing.
I know, I’m looking at the code and trying to find out what’s wrong. And that setting above is used there.
Did it work with a previous OSMC version?
Rather a lot of files seem to be playing wrongly, and I’m pretty sure at least some of them must have worked before. For example, there are episodes of TV series not working when I’ve played previous episodes of the same series without any problem.
In fact, it seems as if something has quite suddenly gone wrong just today - although I’m racking my brains to think of any change I’ve made to the system that could have triggered it. It’s very odd.
If you skip out the Lumagen, does it work?
