What WiFi adapter
Hi guys, just installed osmc with no problems on my RPI, but my edimax dongle doesn’t work. Can anyone recommend a dongle that will work out of the box ?
Stu
I use this one. Works perfectly.
TP-Link TL-WN725N
Im running the one from the osmc store, works really good
I have a D-Link DWA-125, just plug and play.
My edimax is working out of box with osmc
I have this one from Adafruit, the antenna makes it work bette from a far, through walls
The smaller ones without antenna a OK, have an wipi, but does not play HD movies or HDTV well if not within a few meters(my experience)…
mine is not working, I’m new on this. Could you help me?
This thread is over seven years old – I suggest doing some reading about the current state of supported adapters as well as providing more information about your setup.
