As per subject line: if I want to check all installed add ons for updates, and download and install latest versions, what’s the simplest way to trigger that?
This works in the osmc skin:
Settings → Add-on browser: Then bring up the left menu and select check for updates.
Other skins check this out:
https://kodi.wiki/view/Add-on_manager
Thanks Tom.
Out of curiosity, is there also a way to do it from the command line?
This may work: kodi-send -a "UpdateLocalAddons()"
https://kodi.wiki/view/List_of_built-in_functions#Add-on_built-in.27s
Thanks Tom.
"UpdateAddonRepos()" should check the installed repos for new versions of repo(eg new versions of addons in the repo), and if auto-update is enabled for the addon, should trigger an auto update “eventually”. I have no clue of time till auto updates of addons.
