So I’ve pulled this as a separate question from another thread.
I have some issues with sound after updating to the latest Vero 4K firmware. Sam tells me:
If I do this I’ll need to ensure all my keymaps on the logitech remote are still assigned correctly. Can anyone confirm please that doing a backup with My OSMC will save those settings?
Also how about my source mounts etc?
Is there anything NOT backed up by the use of My OSMC?
If the above is backing everything up, then to reinstall my last working build should be as simple as:
- Backup all settings to USB using My OSMC
- Download [2022.03-1] image and install using standard OSMC installer
- Reinstall all my backed up settings using My OSMC
Then all should be good to go - Is that correct please or have I forgotten something?
-Mat
