hello,
Why is it that when I restart my Vero, my PS4 that is turned off turns on?
For my part, it’s a HDMI issue but I don’t know how to fix it.
FYI, my HDMI amp is a Marantz NR1605.
Rgds
Akhlan
hello,
Rgds
Akhlan
Check CEC options in System Settings.
I don’t know what to check…
Settings->System->Input->Peripherals
Yeah, I wish it was disabled as standard, first week i had my vero 4k, dont know if there was a power cut or system rebooted, but turned bedroom tv on in middle of night
Per default it is enabled on all devices,
also on your TV.
I think, this is for easy use out-of-the-box.
I have exactly the same behavior.
Vero 4k+ and ps4 are connected to marantz sr6014. I have everything disabled in cec on kodi and when I reboot vero, ps4 turns on. I also have Nintendo switch on it, and that one doesn’t turn on. Only the ps4
That’s because Vero will de-assert HPD when it reboots; and your TV will then wake any other connected device. It is probably configurable in your TV settings.
nobody have resolved this issue today ?
Did you check cec settings?
I don’t understand CEC settings…
Set “Devices to turn on during startup” to None.
tks ooZee, i try asap
