In “When the TV is switched off” setting I can see following options:
Quit
Hibernate
Suspend
Shutdown
Ignore
Pause Playback
Stop Playback
Can somebody explain the difference between Quit and Shutdown, Hibernate and Suspend. Also which is the best option to set when TV is switched off. My requirements are:
It should consume least power
TV playback should be stopped so that it does not hog the bandwidth
It will quit Kodi and then Kodi will be started again (due to the watchdog restarting it).
Even with energy prices as they are – the Pi 3 does not consume a lot of power and you won’t save more than a couple of pounds a year.
If you pull the plug, yes, if you turn it off safely, no.
