Logs here https://paste.osmc.tv/ukukiwugon
I dont see anything in /dev ie /dev/dvb
From /sys/kernel/debug/usb/devices
T: Bus=01 Lev=02 Prnt=02 Port=04 Cnt=02 Dev#= 4 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=2040 ProdID=826d Rev= 1.00
S: Manufacturer=HCW
S: Product=955D
S: SerialNumber=0014022964
C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=500mA
I:* If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
E: Ad=84(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=85(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I: If#= 0 Alt= 1 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
DMESG below but I think yu have them at the URL above ?
0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.34-6-osmc (root@vero3-db) (gcc version 6.3.0 20170516 (Debian 6.3.0-18+deb9u1)) #1 SMP PREEMPT Thu Sep 6 00:47:56 UTC 2018
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] cma: Reserved 8 MiB at 0x2f800000
[ 0.000000] On node 0 totalpages: 196608
[ 0.000000] free_area_init_node: node 0, pgdat 80f7b5c0, node_mem_map af136000
[ 0.000000] Normal zone: 1728 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 196608 pages, LIFO batch:31
[ 0.000000] random: fast init done
[ 0.000000] percpu: Embedded 17 pages/cpu @af0df000 s39756 r8192 d21684 u69632
[ 0.000000] pcpu-alloc: s39756 r8192 d21684 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 194880
[ 0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=720 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait quiet osmcdev=rbp2
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 754480K/786432K available (9216K kernel code, 540K rwdata, 2012K rodata, 2048K init, 715K bss, 23760K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xb0800000 - 0xff800000 (1264 MB)
lowmem : 0x80000000 - 0xb0000000 ( 768 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x80a00000 (10208 kB)
.init : 0x80d00000 - 0x80f00000 (2048 kB)
.data : 0x80f00000 - 0x80f87120 ( 541 kB)
.bss : 0x80f90d40 - 0x81043c24 ( 716 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 22988 entries in 68 pages
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000018] Switching to timer-based delay loop, resolution 52ns
[ 0.000233] Console: colour dummy device 80x30
[ 0.000249] console [tty0] enabled
[ 0.000269] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=192000)
[ 0.000285] pid_max: default: 32768 minimum: 301
[ 0.000569] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000584] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001565] Disabling memory control group subsystem
[ 0.001634] CPU: Testing write buffer coherency: ok
[ 0.002016] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.040036] Setting up static identity map for 0x100000 - 0x10003c
[ 0.060024] Hierarchical SRCU implementation.
[ 0.100078] smp: Bringing up secondary CPUs …
[ 0.170476] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.240522] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.310630] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.310735] smp: Brought up 1 node, 4 CPUs
[ 0.310747] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.310752] CPU: All CPU(s) started in HYP mode.
[ 0.310757] CPU: Virtualization extensions available.
[ 0.311541] devtmpfs: initialized
[ 0.320552] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.320769] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.320786] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.321368] pinctrl core: initialized pinctrl subsystem
[ 0.322103] NET: Registered protocol family 16
[ 0.342324] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.345909] cpuidle: using governor ladder
[ 0.345939] cpuidle: using governor menu
[ 0.346203] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.346211] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.346391] Serial: AMBA PL011 UART driver
[ 0.347936] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.348367] uart-pl011 3f201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
[ 0.375861] bcm2835-dma 3f007000.dma: DMA legacy API manager at b0813000, dmachans=0x1
[ 0.377122] SCSI subsystem initialized
[ 0.377322] usbcore: registered new interface driver usbfs
[ 0.377370] usbcore: registered new interface driver hub
[ 0.377455] usbcore: registered new device driver usb
[ 0.380726] raspberrypi-firmware soc:firmware: Attached to firmware from 2018-08-10 11:25
[ 0.381671] clocksource: Switched to clocksource arch_sys_counter
[ 0.457374] VFS: Disk quotas dquot_6.6.0
[ 0.457452] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.457646] FS-Cache: Loaded
[ 0.457844] CacheFiles: Loaded
[ 0.465965] NET: Registered protocol family 2
[ 0.466624] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.466734] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.466920] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.467045] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.467089] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.467402] NET: Registered protocol family 1
[ 0.467843] RPC: Registered named UNIX socket transport module.
[ 0.467849] RPC: Registered udp transport module.
[ 0.467854] RPC: Registered tcp transport module.
[ 0.467860] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.570895] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 0.571774] audit: initializing netlink subsys (disabled)
[ 0.571989] audit: type=2000 audit(0.569:1): state=initialized audit_enabled=0 res=1
[ 0.572617] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 0.579693] FS-Cache: Netfs ‘nfs’ registered for caching
[ 0.580239] NFS: Registering the id_resolver key type
[ 0.580265] Key type id_resolver registered
[ 0.580271] Key type id_legacy registered
[ 0.580286] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.585048] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.585175] io scheduler noop registered (default)
[ 0.585434] io scheduler bfq registered
[ 0.588238] BCM2708FB: allocated DMA memory ef910000
[ 0.588264] BCM2708FB: allocated DMA channel 0 @ b0813000
[ 0.598216] Console: switching to colour frame buffer device 90x30
[ 0.604455] bcm2835-rng 3f104000.rng: hwrng registered
[ 0.604576] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 0.605008] vc-sm: Videocore shared memory driver
[ 0.613795] brd: module loaded
[ 0.620140] loop: module loaded
[ 0.620153] Loading iSCSI transport class v2.0-870.
[ 0.620801] libphy: Fixed MDIO Bus: probed
[ 0.620884] usbcore: registered new interface driver lan78xx
[ 0.620939] usbcore: registered new interface driver smsc95xx
[ 0.620954] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.848996] Core Release: 2.80a
[ 0.849006] Setting default values for core params
[ 0.849026] Finished setting default values for core params
[ 1.049238] Using Buffer DMA mode
[ 1.049245] Periodic Transfer Interrupt Enhancement - disabled
[ 1.049250] Multiprocessor Interrupt Enhancement - disabled
[ 1.049257] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.049266] Dedicated Tx FIFOs mode
[ 1.049628] WARN::dwc_otg_hcd_init:1046: FIQ DMA bounce buffers: virt = 0xaf904000 dma = 0xef904000 len=9024
[ 1.049654] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 1.049661] dwc_otg: Microframe scheduler enabled
[ 1.049710] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x80752094
[ 1.049722] WARN::hcd_init_fiq:460: FIQ ASM at 0x807523ec length 36
[ 1.049734] WARN::hcd_init_fiq:486: MPHI regs_base at 0xb087e000
[ 1.049790] dwc_otg 3f980000.usb: DWC OTG Controller
[ 1.049821] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 1.049850] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ 1.049895] Init: Port Power? op_state=1
[ 1.049900] Init: Power Port (0)
[ 1.050121] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.050132] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.050140] usb usb1: Product: DWC OTG Controller
[ 1.050149] usb usb1: Manufacturer: Linux 4.14.34-6-osmc dwc_otg_hcd
[ 1.050157] usb usb1: SerialNumber: 3f980000.usb
[ 1.050696] hub 1-0:1.0: USB hub found
[ 1.050734] hub 1-0:1.0: 1 port detected
[ 1.051219] dwc_otg: FIQ enabled
[ 1.051224] dwc_otg: NAK holdoff enabled
[ 1.051230] dwc_otg: FIQ split-transaction FSM enabled
[ 1.051247] Module dwc_common_port init
[ 1.051474] usbcore: registered new interface driver usb-storage
[ 1.051622] mousedev: PS/2 mouse device common for all mice
[ 1.051979] usbcore: registered new interface driver usbtouchscreen
[ 1.052322] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 1.052575] bcm2835-cpufreq: min=600000 max=1200000
[ 1.054379] sdhci: Secure Digital Host Controller Interface driver
[ 1.054382] sdhci: Copyright(c) Pierre Ossman
[ 1.054568] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
[ 1.054729] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ 1.054774] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.055834] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.055925] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.056042] usbcore: registered new interface driver usbhid
[ 1.056045] usbhid: USB HID core driver
[ 1.056449] vchiq: vchiq_init_state: slot_zero = af980000, is_master = 0
[ 1.057405] [vc_sm_connected_init]: start
[ 1.064404] [vc_sm_connected_init]: end - returning 0
[ 1.064712] Initializing XFRM netlink socket
[ 1.064724] NET: Registered protocol family 17
[ 1.064777] Key type dns_resolver registered
[ 1.064845] Registering SWP/SWPB emulation handler
[ 1.065124] registered taskstats version 1
[ 1.065573] Key type encrypted registered
[ 1.068444] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 1.068493] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ 1.069244] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ 1.069248] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[ 1.142008] sdhost: log_buf @ af907000 (ef907000)
[ 1.167336] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.168827] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.170320] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.173002] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.221705] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 1.222219] of_cfs_init
[ 1.222271] of_cfs_init: OK
[ 1.225412] Freeing unused kernel memory: 2048K
[ 1.271767] Indeed it is in host mode hprt0 = 00021501
[ 1.292464] mmc1: new high speed SDIO card at address 0001
[ 1.351383] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.355305] mmc0: new high speed SDHC card at address aaaa
[ 1.355627] mmcblk0: mmc0:aaaa SE32G 29.7 GiB
[ 1.356822] mmcblk0: p1 p2
[ 1.491679] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.491762] Indeed it is in host mode hprt0 = 00001101
[ 1.731810] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 1.731816] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.732155] hub 1-1:1.0: USB hub found
[ 1.732213] hub 1-1:1.0: 5 ports detected
[ 2.051674] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.181809] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.181814] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.184108] smsc95xx v1.0.6
[ 2.273516] smsc95xx 1-1.1:1.0 eth0: register ‘smsc95xx’ at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:02:a3:8a
[ 2.381747] usb 1-1.5: new high-speed USB device number 4 using dwc_otg
[ 2.417901] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.424192] fsck: E2fsck run: /bin/e2fsck -p -C 0 /dev/mmcblk0p2
[ 2.424339] fsck: Filesystem UUID: 1ce84604-6b05-49b9-92bd-7f1e52f43561
[ 2.424479] fsck: Filesystem UUID: 1ce84604-6b05-49b9-92bd-7f1e52f43561
[ 2.424612] fsck: Setting free inodes count to 1899696 (was 1899728)
[ 2.424745] fsck: Setting free blocks count to 7332856 (was 7333143)
[ 2.424907] fsck: /dev/mmcblk0p2: clean, 33616/1933312 files, 396040/7728896 blocks
[ 2.522221] usb 1-1.5: New USB device found, idVendor=2040, idProduct=826d
[ 2.522231] usb 1-1.5: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 2.522235] usb 1-1.5: Product: 955D
[ 2.522240] usb 1-1.5: Manufacturer: HCW
[ 2.522244] usb 1-1.5: SerialNumber: 0014022964
[ 3.429180] systemd[1]: System time before build time, advancing clock.
[ 3.479506] NET: Registered protocol family 10
[ 3.480232] Segment Routing with IPv6
[ 3.489267] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.508206] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 3.508495] systemd[1]: Detected architecture arm.
[ 3.509211] systemd[1]: Set hostname to <adams_mm1>.
[ 3.756841] systemd[1]: Set up automount boot.automount.
[ 3.757333] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.757509] systemd[1]: Listening on udev Control Socket.
[ 3.757646] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.757740] systemd[1]: Listening on udev Kernel Socket.
[ 3.758126] systemd[1]: Created slice User and Session Slice.
[ 3.758187] systemd[1]: Reached target Swap.
[ 3.890006] systemd-journald[164]: Received request to flush runtime journal from PID 1
[ 4.203528] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 4.336244] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.337657] bcm2835_alsa bcm2835_alsa: card created with 8 channels
[ 4.538181] brcmfmac: brcmf_fw_map_chip_to_name: using brcm/brcmfmac43430-sdio.bin for chip 0x00a9a6(43430) rev 0x000001
[ 4.538321] usbcore: registered new interface driver brcmfmac
[ 4.699471] uart-pl011 3f201000.serial: no DMA platform data
[ 4.720176] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Oct 23 2017 03:55:53 version 7.45.98.38 (r674442 CY) FWID 01-e58d219f
[ 4.720813] brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 7.11.15 Compiler: 1.24.2 ClmImport: 1.24.1 Creation: 2014-05-26 10:53:55 Inc Data: 9.10.39 Inc Compiler: 1.29.4 Inc ClmImport: 1.36.3 Creation: 2017-10-23 03:47:14
[ 5.500289] nf_conntrack version 0.5.0 (12288 buckets, 49152 max)
[ 5.833332] smsc95xx 1-1.1:1.0 eth0: hardware isn’t capable of remote wakeup
[ 5.833637] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 5.886687] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 5.886699] brcmfmac: power management disabled
[ 6.296462] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 6.913329] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 7.371858] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 7.372686] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
[ 7.391978] 8021q: 802.1Q VLAN Support v1.8
[ 9.221617] Bluetooth: Core ver 2.22
[ 9.221719] NET: Registered protocol family 31
[ 9.221723] Bluetooth: HCI device and connection manager initialized
[ 9.221736] Bluetooth: HCI socket layer initialized
[ 9.221743] Bluetooth: L2CAP socket layer initialized
[ 9.221763] Bluetooth: SCO socket layer initialized
[ 9.244666] Bluetooth: HCI UART driver ver 2.3
[ 9.244675] Bluetooth: HCI UART protocol H4 registered
[ 9.244678] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 9.556682] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 9.556690] Bluetooth: BNEP filters: protocol multicast
[ 9.556704] Bluetooth: BNEP socket layer initialized
[ 10.797149] Console: switching to colour dummy device 80x30
[ 27.358755] random: crng init done
osmc@adams_mm1:~$
For the firmware I followed this up and it looks like I have the firmware in /lib/firmware
If this was the issue I would have thought I would see an error from the driver as it failed to find the firmware. Do you use devicetree and if so does the driver for this device have to be setup from devicetree so that it will try and detect and load the device with the firmware
UPDATE
I found this thread
and half way down they are saying that kernel 4.14 doesnt support this device so I think I have to get another device or move to a different setup.
