Hi, I’ve been running OSMC on a Pi2B for a while, regularly updating it. For a few months I’ve been backing up my linux (ClearOS) server to a 250GB 2.5" USB disk connected to the Pi. The Pi is currently powered by a 3A PSU and has been fine on it (no power warning). This week the backup (rsync) failed and I think I’ve tracked it down to a lack of space (apt-get clean freed ~1GB and it is working now) but I can’t see where it has gone. I have the following:
root@osmc:/# df -h
Filesystem Size Used Avail Use% Mounted on
devtmpfs 362M 0 362M 0% /dev
tmpfs 367M 5.1M 362M 2% /run
/dev/mmcblk0p2 7.0G 5.7G 920M 87% /
tmpfs 367M 0 367M 0% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 367M 0 367M 0% /sys/fs/cgroup
/dev/mmcblk0p1 240M 21M 219M 9% /boot
/dev/sda1 230G 143G 75G 66% /mnt/USBDisk
tmpfs 74M 0 74M 0% /run/user/0
root@osmc:/# du -h --max-depth=1
47M ./opt
0 ./sys
117M ./var
4.0K ./lib64
5.1M ./run
91M ./lib
6.2M ./bin
5.0M ./sbin
143G ./mnt
4.0K ./srv
21M ./boot
4.0K ./selinux
16K ./lost+found
24K ./tmp
5.0M ./etc
8.0K ./media
0 ./dev
du: cannot access './proc/1/task/1/fd/16': No such file or directory
du: cannot access './proc/570/task/570/fd/3': No such file or directory
du: cannot access './proc/570/task/570/fdinfo/3': No such file or directory
du: cannot access './proc/570/fd/4': No such file or directory
du: cannot access './proc/570/fdinfo/4': No such file or directory
0 ./proc
588M ./usr
212K ./root
200M ./home
144G .
The 143G is the USB disk mounted under /mnt.
root@osmc:/# fdisk -l
Disk /dev/ram0: 4 MiB, 4194304 bytes, 8192 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk /dev/ram1: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram2: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram3: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram4: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram5: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram6: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram7: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram8: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram9: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram10: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram11: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram12: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram13: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram14: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram15: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/mmcblk0: 7.4 GiB, 7948206080 bytes, 15523840 sectors
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x0003d932
Device Boot Start End Sectors Size Id Type
/dev/mmcblk0p1 2048 499711 497664 243M c W95 FAT32 (LBA)
/dev/mmcblk0p2 501760 15523839 15022080 7.2G 83 Linux
Disk /dev/sda: 232.9 GiB, 250059350016 bytes, 488397168 sectors
Disklabel type: dos
Disk identifier: 0xdb75393d
/dev/sda1 2048 488396799 488394752 232.9G 83 Linux
So I can see from fdisk -l I have 7.2GB, but the output of du -h does not give anywhere near 5.9GB excluding /mnt and /boot. How can I track down the missing space?
I am comfortable with the linux command line but more familiar with Fedora based systems.
