reproduce the issue
I’m not as big an idiot as it may seem at first glance.
If I restart from the KODI menu, only the Vero 4k + restarts, but the DVB-T2 / DVB-C TV dongle will most likely NOT restart due to power from the 4 Port USB 3.0 Powered Hub.
After the restart is completed, the DVB-T2 / DVB-C TV dongle for KODI is not available.
Nobody said that. But you asked how to do it. Now finally we know what the problem is. I have the same setup but with a different USB hub. Normally I can warm-boot Vero without problems but if that doesn’t work the only way to be sure is to cold start both the hub and Vero. What I’ve never really nailed is if the order in which you start them matters. Starting Vero first should always work so if you have nothing else on that USB hub that’s needed at start-up, do it in that order.
Does that help?
But then I just thought: with the OSMC hub, the technique would have to be turn each USB socket off with the switches, then start Vero, then power on the hub and switch each dongle on in turn.
I have an easier way, I disconnect the USB hub from Vero after confirming the restart and I connect it again after restarting Vero. However, this stupid procedure bothers me.
i had the same problem with backfeeding. The easiest way is to buy short usb cable and cut +5V line to make it just data or you can use tape to isolate +5V contact. This will divide power feeding between hub and vero.
There is no other solution yet. At least i dont know it.
I would need a bit more info about your 4K+ device to solve this, but from the fact that you’ve posted nearly three years later I will assume that this is a testament to the high uptime of the device
