When I change HDMI selection from TV to OSMC my surround sound system has started to power up automatically. This only started to happen a few weeks back following an OSMC update. I’ve checked the ‘peripherals’ settings, where I usually configure what starts and stops with OSMC but can’t find an option for this, Does anyone know why this has started to happen??
Assuming you’re talking about the settings in the ‘Input devices’ ‘Peripherals’, then that’s what I thought but the ‘Devices to power on during startup’ is set to None and that’s the way I’ve always had it set. Is there another config section I need to check?
It wasn’t this weeks release or the previous one. I think it was the release prior to that. End of July?
This could be a red herring but did anything change in the ‘Audio output’ section. The text in the ‘Audio output device’ looks to have a changed but I could be imagining that
