I’m unsure if this is the update to 18 as I’d not noticed it before.
I’d noticed that the deinterlacing options were greyed out whilst watching Millenium (NTSC 29.97Hz 480i), and also watching That Mitchel and Webb (PAL 25Hz 576i) proved to be impossible because the content was not actually deinterlaced properly at all.
I’ve now set MPEG-2 to decode in software for less than HD and it’s now perfectly deinterlaced.
What is happening with the hardware decode that causes it to be so bad? The stair steps are so bad it looks like blocky video.
Thoughts?
This is the NTSC video:
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings : CustomMatrix / BVOP
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : Variable
Codec ID : V_MPEG2
Codec ID/Info : MPEG 1 or 2 Video
Bit rate mode : Variable
Bit rate : 5 056 kb/s
Maximum bit rate : 9 800 kb/s
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Original frame rate : 23.976 FPS
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Scan order : 2:3 Pulldown
Compression mode : Lossy
Time code of first frame : 00:59:59;15
Time code source : Group of pictures header
GOP, Open/Closed : Open
GOP, Open/Closed of first frame : Closed
Language : English
Default : No
Forced : No
Color primaries : BT.601 NTSC
Transfer characteristics : BT.601
Matrix coefficients : BT.601
This is the PAL:
Video
Format : MPEG Video
Format settings : BVOP
Format settings, Matrix : Default
Format settings, GOP : M=3, N=13
Format settings, picture structure : Frame
Codec ID : V_MPEG2
Duration : 29 min 8 s
Bit rate : 4 458 kb/s
Maximum bit rate : 9 000 kb/s
Width : 720 pixels
Height : 576 pixels
Original display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 25.000 FPS
Standard : PAL
Color space : YUV
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.430
Time code of first frame : 10:00:00:00
Stream size : 929 MiB (94%)
Language : English
Default : Yes
Forced : No
Color primaries : BT.601 PAL
Transfer characteristics : BT.470 System B/G
Matrix coefficients : BT.470 System B/G
