Latest OSMC running on Raspberry Pi 3 Model B Plus Rev 1.3.
Seems like with the last OSMC update, my Wi-Fi started dropping out randomly for some reason.
I can either restart RPi or I can also fiddle with network settings but it will never reconnect on its own.
The error always starts at this line in logs:
Jun 19 05:20:40 osmc wpa_supplicant[202]: wlan0: CTRL-EVENT-DISCONNECTED bssid=68:e2:09:65:af:f4 reason=0 locally_generated=1
Jun 19 05:20:40 osmc wpa_supplicant[202]: dbus: wpa_dbus_property_changed: no property SessionLength in object /fi/w1/wpa_supplicant1/Interfaces/1
replace wlan0 with the appropriate interface if its not it sometimes the wifi signal is just bad, instead of just checking logs
should reproduce a log like this
wlan0 IEEE 802.11abgn ESSID:"redacted"
Mode:Managed Frequency:5.18 GHz Access Point: 74:44:44:44:57:FC
Bit Rate=6 Mb/s Tx-Power=15 dBm
Retry long limit:7 RTS thr:off Fragment thr:off
Encryption key:off
Power Management:off
Link Quality=41/70 Signal level=-69 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:28 Missed beacon:0
the important part is
tells you if you need to move your rpi to a better spot
my experiance is somewhere around 40-58 ish db for 2.4 ghz is nice the further higher up you are the shitter the signal gets the less good transfer rates you will get
for 5gzh you can stretch it a little bit more before it gets shitty
I will just add that I had this setup for years and it only started happening in the last couple months but I didn’t have time to deal with it so I always just restarted Kodi before using it.
osmc@osmc:~$ iwconfig wlan0
wlan0 IEEE 802.11 ESSID:"xxxxxx"
Mode:Managed Frequency:5.24 GHz Access Point: 68:E2:09:65:AF:F4
Bit Rate=433.3 Mb/s Tx-Power=31 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:on
Link Quality=55/70 Signal level=-55 dBm
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
its not always about where you got your stuff its, about where your neighbors etc, new stuff added that can negatively effect wifi signal, in the end its just a simple radio signal thats easily effected by multiple stuff in its environment but looking at the sure it looks ok some short retries but nothing that sticks out.
