The OSMC wifi listing (in the vero app) doesn’t support displaying unicode characters in the SSID list, but the wifi spec allows for it. My wifi has a unicode character in it (for vanity purposes), and I would love to be able to see it in the wifi list on the vero. Could y’all add unicode character support to the wifi SSId selection menu?
I’m sure we can.
In the interim, do you have an opportunity to connect via the command line?
I can give you SSH instructions if you run an Ethernet cable or even attach a USB keyboard temporarily.
We have had a look at this and it seems it should work.
Could you upload a log and if possible, let us know the name of your WiFi network?
I have ssh access to the device.
My wifi network is named “
What do you want a log of?
