[2.536639] usb 1-1.2: Product: 802.11 n WLAN
[2.536655] usb 1-1.2: Manufacturer: Ralink
[2.536670] usb 1-1.2: SerialNumber: 1.0
[4.590562] random: systemd urandom read with 81 bits of entropy available
[4.711555] NET: Registered protocol family 10
[5.851713] systemd[1]: Cannot add dependency job for unit display-manager.se rvice, ignoring: Unit display-manager.service failed to load: No such file or di rectory.
[6.328801] fuse init (API version 7.23)
[6.378775] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[7.268724] systemd-udevd[95]: starting version 215
[8.748986] cfg80211: Calling CRDA to update world regulatory domain
[9.388709] usb 1-1.2: reset high-speed USB device number 4 using dwc_otg
[9.502260] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 5390, rev 0502 d etected
[9.504777] random: nonblocking pool is initialized
[9.770674] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 5370 detected
[9.833220] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[9.842536] usbcore: registered new interface driver rt2800usb
[9.845207] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[11.409747] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[13.540667] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[13.541404] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[13.654739] systemd-journald[75]: Received request to flush runtime journal f rom PID 1
[13.876091] Adding 131068k swap on /swap. Priority:-1 extents:6 across:27033 6k SSFS
[14.688924] ieee80211 phy0: rt2x00lib_request_firmware: Info - Loading firmwa re file 'rt2870.bin'
[14.700998] ieee80211 phy0: rt2x00lib_request_firmware: Info - Firmware detec ted - version: 0.29
[15.036205] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[15.072316] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[15.077397] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E 1
[24.651800] Console: switching to colour dummy device 80x30
My Wi-Pi didn’t work either (or rather the network setup didn’t work) untill I went through the manual guide in this thread. Now it works perfectly - and after updating I think I can even change the settings from the GUI.
