While the dmesg doesn’t give a specifc info your lsub above show “no firmware”
So my guess is the firmware is missing. Read here ath9k_htc - Debian Wiki
Install firmware-atheros conflicts with wireless-firmware-osmc:
root@osmc:~# apt-get install firmware-atheros
Reading package lists… Done
Building dependency tree
The following packages were automatically installed and are no longer required:
libbluray1 rbp2-image-4.3.0-9-osmc
Use ‘apt-get autoremove’ to remove them.
Suggested packages:
initramfs-tools
firmware-atheros
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/873 kB of archives.
After this operation, 1,803 kB of additional disk space will be used.
(Reading database … 29761 files and directories currently installed.)
Preparing to unpack …/firmware-atheros_0.43_all.deb …
Unpacking firmware-atheros (0.43) …
dpkg: error processing archive /var/cache/apt/archives/firmware-atheros_0.43_all.deb (–unpack):
trying to overwrite ‘/lib/firmware/htc_7010.fw’, which is also in package wireless-firmware-osmc 1.1.0
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
But i’ve dowloaded the package and extracted the htc_7010.fw is exactly the same that comes in the package wireless-firmware-osmc.
Also another strange thing, i went back o my RPY1 with RASPBMC and checked lsusb and id’s are different:
Bus 001 Device 006: ID 0846:9018 NetGear, Inc. WNDA3200 802.11abgn Wireless Adapter [Atheros AR7010+AR9280]
It seems both RaspBMC and OSMC detects it as a mass storage device (CD-ROM).
RaspBMC must have something configured for doing de usb mode switch.
In this site they use the eject command, and after the eject command it now apears as a wifi dongle.
I’ve tried on OSMC and it works, for now i’m going do add the eject command to the rc.local, but i’m going to try to configure usb_modeswitch in order to fix this.
I don’t have /lib/udev/rules.d/40-usb_modeswitch.rules on my system - are you sure you didn’t copy this file from your Raspbmc install and expect it to work ?
Because both RASPBMC and OSMC have the usb-modeswitch package installed:
root@osmc:~# dpkg -l | grep usb-mode
ii usb-modeswitch 2.2.0+repack0-2 armhf mode switching tool for controlling “flip flop” USB devices
ii usb-modeswitch-data 20150115-1 all mode switching data for usb-modeswitch
Then you must have manually installed it, because I can confirm that it is not available on my default OSMC installation.
So you mean now evenso you have the usb-modeswitch script and you have the UDEV rule the WIFI is not working?
What happens if you manually call the usb-modeswitch script?
I was trying to call the usb_modeswitch and i found that the /usr/share/usb_modeswitch/ directory only contained the file configPack.tar.gz,
so i extracted this archive and i now got all the usb_modeswitch configuration files there, specially the 0cf3:20ff
Most likely an upstream Debian issue - we don’t do anything special to udev that should prevent this working - we use standard Debian systemd and udev packages.
I’d suggest a Google search for the same issue on Debian Jessie to see if anything turns up.
