Wifi disconnect
hello,
i’m working on ssh on my Vero 4k, and the network disconnect about 15-20min. (on wifi)
log: https://paste.osmc.tv/eluvapaxod
message of my ssh client:
16:17:53.838 The SSH session has terminated with error. Reason: FlowSocketReader: Error receiving bytes.
so i need to go on the TV, “My osmc” menu, network and i reconnect on my network.
Thanks for you support.
Ben
Do you have more than one AP?
Jan 07 15:16:42 osmc wpa_supplicant[2369]: wlan0: CTRL-EVENT-DISCONNECTED bssid=60:8d:26:9f:ea:f0 reason=12
Jan 07 15:16:42 osmc kernel: [dhd-wlan0] wl_iw_event : disconnected with 60:8d:26:9f:ea:f0, event 6, reason 12
Jan 07 15:16:42 osmc kernel: [dhd-wlan0] wl_ext_iapsta_event : [S] Link down with 60:8d:26:9f:ea:f0, WLC_E_DEAUTH_IND(6), reason 12
Jan 07 15:16:42 osmc kernel: [dhd] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_DEAUTH_IND
Jan 07 15:16:42 osmc kernel: [dhd-wlan0] wl_notify_connect_status : link down if wlan0 may call cfg80211_disconnected. event : 6, reason=12 from 60:8d:26:9f:ea:f0
Jan 07 15:16:42 osmc kernel: [dhd] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_LINK
what is AP ?
Access Point
no i have only one AP, the same name for 2.4GHz and 5Ghz, but my wifi adapter can’t connect on the 5Ghz. So it use only the first
i’ve separated 2.4Ghz and 5Ghz and force the channel. Now it seem ok
Disable Band Steering on your Router if enabled.
thanks :wink:
Did this solve your problem?
Can you let me know the model of your router and the exact setting you disabled? This may help other users in the future.
