I’m running latest OSMC on Raspberry Pi 3. After few hours of working the WiFi adapter disconnected from the AP and couldn’t connect anymore.
What’s connected to RPi 3:
external 2,5" hard drive via USB (additional power via second USB cable, provided from the same power adapter as RPi)
Samsung TV via HDMI
How to reproduce
I didn’t do anything specific. I started RPi and some files were downloading to the RPi via WiFi. It was like that for about 4hours and after that I tried to use TV streaming addons when I realized there’s no WiFi.
I tried to disable and after few seconds enable Wireless adapter via OSMC but no luck.
I connected via ethernet cable and SSH to check what’s going on and upload the logs.
Power supply I use specifies that is able to provide 4,8A. It has 3 USB ports. So I think it should be enough.
I also did some test to create a heavy load on RPi to be sure the supply provides enough power.
I did run 4 processes of “cat /dev/urandom > /dev/null” and also was playing 1080p movie at the same time. There were no indications of lack of power.
I now umounted the drive and disconnected it. Again disabled/enabled wireless adapter but it still didn’t connect to AP.
That 4.8 is probably total from all three ports and each individual one is probably 1.6 each at most. Which would be to low for the Pi 3’s recommended 2.5
It was fine for some time so I forgot about this thread… but now I face this problem again.
I powering the Pi from original 2,5A 5.1V Raspberry Pi 3 power adapter and still get those errors:
May 09 21:24:25 osmc kernel: brcmfmac: brcmf_sdio_hostmail: Unknown mailbox data content: 0x40012
May 09 22:00:15 osmc kernel: brcmfmac: brcmf_sdio_bus_txdata: out of bus->txq !!!
May 09 22:00:18 osmc kernel: brcmfmac: brcmf_sdio_bus_txdata: out of bus->txq !!!
May 10 00:51:10 osmc kernel: brcmfmac: brcmf_cfg80211_get_tx_power: error (-52)
May 10 00:51:12 osmc kernel: brcmfmac: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
May 10 00:53:16 osmc kernel: brcmfmac: brcmf_do_escan: error (-52)
May 10 00:53:16 osmc kernel: brcmfmac: brcmf_cfg80211_scan: scan error (-52)
