I’m running Pi 3B with an up-to-date version of OSMC. I can start WiFi from the OSMC page (“My OSMC”->“Network”->wireless) and it seems to be working. However if I reboot, the WiFi connection does not restart. I can manually restart it, but that will not work in general, I will need WiFi when I move the Pi to my TV area.
As long as I don’t reboot I can also SSH into the Pi thus I know that the WiFi connection is working.
Also, I don’t see where I can reset the password if someday I should be changing it.
OK, I think I did it correctly. after the reboot I reconfigured the WiFi, did a log upload which I think failed, but a second upload seemed to work as I was able to get to the URL.
You actually have two wired connections, each on a different subnet, plus the WiFi connection on the same subnet as eth0. It might be that connman decides that after creating two wired connections, you clearly don’t need a third (wireless) connection.
Please restart the Pi. Without’t manually starting WiFi, please run the following commands:
Yes, having the two wired connections is temporary. When I move it to the TV area I will only have one connection to LAN A and the WiFi to LAN B. Here is the output you requested. Later I will do an experiment with only the final, ie at the TV, network setup. Thanks…RDK
