Hello,
I’m trying to diagnose a problem I’m having with memory on my Pi3B elsewhere. I use the OSMC wifi dongle to connect at 5G. The memory problem seems to be related to the dongle or its driver.
I seem to have everything working on a new SD card but now my wifi fails to connect after rebooting the Pi. I’m trying to relate memory leakage to wifi and can’t do that completely unless the Pi reconnects after a reboot. Each morning at 0300, I reboot the Pi via a cronjob. When I was using an “old” SD card, wifi connected correctly after the cron reboot. On my new, fresh installation, it is not. Both yesterday morning and this morning, wifi was not connected when I attempted to gather data.
To connect, I went to MyOSMC>Network. Wired was disabled (as I had previously specified) and wireless was enabled, but not connected. I backed out of Network and then went back in, clicked on wireless, and, lo and behold, I was connected!
I grabbed logs and they are here: https://paste.osmc.tv/emezogiyow I hope they’re helpful.
I looked at previous postings on this topic and was unable to figure out what else I needed to do. I’ll also add that I had this same behavior on the “old” SD card. It persisted for awhile but then one day began connecting correctly after a reboot.
Thanks for any help.
