I could not make this wifi dongle work. Is it supported?
The usb-devices shows:
T: Bus=01 Lev=02 Prnt=02 Port=01 Cnt=02 Dev#= 4 Spd=480 MxCh= 0
D: Ver= 2.01 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=0b05 ProdID=17d1 Rev=01.00
S: Manufacturer=MediaTek
S: Product=WiFi
S: SerialNumber=1.0
C: #Ifs= 1 Cfg#= 1 Atr=a0 MxPwr=160mA
I: If#= 0 Alt= 0 #EPs= 8 Cls=ff(vend.) Sub=02 Prot=ff Driver=rt2870
The diff on lsmod between onboard and the dongle is:
-8189es 818456 0 +8021q 16487 0 Module Size Used by am_net8218_osmc 31525 0 cbc 2022 0 -cfg80211 182470 1 8189es +cfg80211 182470 1 mt7610u_sta fuse 67174 1 ir_jvc_decoder 1389 0 ir_lirc_codec 3807 3 @@ -15,6 +15,5 @@ lirc_dev 7688 1 ir_lirc_codec mali 161090 5 meson_ir 2413 0 +mt7610u_sta 819291 0 rc_core 12598 11 ir_sharp_decoder,lirc_dev,meson_ir,ir_lirc_codec,ir_rc5_decoder,ir_nec_decoder,ir_sony_decoder,ir_mce_kbd_decoder,ir_jvc_decoder,ir_sanyo_decoder -sha1_arm 3126 0 -sha1_generic 1624 0
The dmesg shows some errors:
WARNING: at net/wireless/reg.c:434 regulatory_init+0x98/0x128 [cfg80211]() db.txt is empty, you should update it... Modules linked in: cfg80211(+) ir_nec_decoder ir_mce_kbd_decoder mali ir_sony_decoder ir_lirc_codec ir_jvc_decoder ir_sanyo_decoder lirc_dev ir_rc5_decoder ir_sharp_dec oder meson_ir rc_core fuse am_net8218_osmc
and
/mnt/package/kernel-osmc/src/vero2-linux-master/drivers/net/wireless/mt7610u/os/linux/../../chips/mt76x0.c:2114 assert (pAd->TxPower[choffset].Channel == 36)failed ERROR!!! E2PROM: WRONG VERSION 0x2, should be 1 mt76x0_read_tx_alc_info_from_eeprom: EEPROM_MT76x0_TEMPERATURE_OFFSET (0xD1) = 0xf8 mt76x0_read_tx_alc_info_from_eeprom: TemperatureOffset = 0xfffffff8 Temperature Tx ALC not enabled
conmann scan wifi, services shows only the ethernet, no error, nothing
While doing conmann stuff dmesg shows
[ 185.022469] 80211> CFG80211_OpsScan ==> [ 187.279093] 80211> cfg80211_scan_done [ 187.279621] 80211> CFG80211_OpsSurveyGet ==> [ 187.279636] 80211> busy time = 512 0
